I
Description :
PhotoFiltre Studio X - software for quick and easy learning curve. It includes tools that allow both to create new works, and to edit already existing images. In PhotoFiltre can adjust the brightness, contrast, saturation, gamma correct, use of filters (watercolor, pastels, ink, etc) Furthermore, this editor can work with the decorative text to optimize the schedule, create greeting cards and envelopes from finished shablonov.Suschestvenno expand program options you can connect to it plugins. In addition, the disposal of the user is more than a hundred filters for image processing, such as watercolor, pastels, the effect of breakage on puzzles, etc.
Features :
- Apply different filters
- The use of two types of vector selection
- Creating and using layers
- Instrument cleaning image
- Tools for the automatic imposition of a transparent gradient
- The function to remove red eye
- Creation of animated GIF-pictures with the built-in generator
- Integrated module FotoMaski
- Create and export 32x32, 48x48, 64x64 Icons
- Integrated browser to view images
installation :
-Install software.
-Generate a serial using keygen
-Go to ? / Registration
-Register
-Done !!
Info :
Language : English
DOWNLOAD
Turbobit
http://turbobit.net/41p8a6qs91hb/PhotoFiltreStudioX.10.12.incPortable.rar.html
Rapidgator
http://rapidgator.net/file/60a156d3...PhotoFiltreStudioX.10.12.incPortable.rar.htm
